Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: kit for cnc is this any good
    Feb 2012
    ireland
    Registered doorknob's Avatar
    Jan 2010
    What do you intend to do with it?
    Some people are successful using those boards, however there are also many tales of woe.
    You may want to read the following thread (it is a long one) for more information:
    http://www.cnczone.com/forums/genera...y_chinese.html
    Feb 2012
    ireland
    i want to build a cnc plasma with about a 4x4 table
    Feb 2012
    England
    Can I suggest you look at individual drivers rather than those all in one boards,simply because I've heard that the chips on those boards if driven to the max limit they tend to pop and render the board with only two axises or even one?
    Not trying to put you off buying em but the net is full of information on those boards.
    Jan 2010
    For comparison purposes, "winegar" used a similar controller but with higher torque motors (420 oz-in) in this build:
    http://www.cnczone.com/forums/plasma...4x4_table.html
    You might want to compare notes over there.
    Feb 2012
    ireland
    im new to cnc so it a big learning curve i need help in picking the electroincs,motors etc
    what do you guys all use?
    would the kit in the link work ok?
    Feb 2012
    England
    How many motors does a plasma table use really?
    Feb 2012
    England
    This is a better kit,its supplied witha bob,better motors and drivers but lacks the 4th motor.
    3 axis Nema23 stepper motor 425oz-in& Drivers CNC controller kit Longs Motor | eBay
    Feb 2012
    ireland
    so if i bought the 3 axis Nema23 stepper motor 425oz-in& Drivers CNC controller kit Longs Motor | eBay that would work for my porject? if i bought will you all help with the setting up
    Feb 2012
    England
    Well anyone will help you out,thats what the sites for innit.
    I don't know about plasma tables and thats why I asked how many motors? I'm only going by the link you posted detailing four motors in the package.
    but the link I posted are better than the rubbish in your link. so if three motors will suffice then thats what I'd go for.
    Feb 2012
    ireland
    thanks so if i bought a 3 axis Nema23 stepper motor 425oz-in& Drivers CNC controller kit Longs Motor |kit from ebay.
    would this be all i need to make it work minous the plasma machine and a coumputer of course?
    will this kit turn of and on the plasma torch?
    and lastly will this machine be able to cut circles cut names etc?
    Feb 2012
    England
    That kit is for general movement of the axises,I think that a switch mec needs applying for the torch.
    Cutting is down to the torch nothing else,so if thhe torch is up to scratch then yeah it will work.
    Read the plasma build link that Doorknob posted further up.
  • Page 1 of 2 12 LastLast
    1. CNCmachines6090 GOOD OR NO GOOD?
      By CNCZONERAMICO in forum Automation Technology Products
      Last Post: 07-28-2008, 05:25 AM
    2. New Machine Build- any good to use
      By simplicity7790 in forum DIY CNC Router Table Machines
      Last Post: 03-25-2008, 12:34 PM
    3. New EDM, Any Good?
      By Spinner in forum General Waterjet
      Last Post: 10-04-2007, 02:58 PM
    4. Tolerance, how good is good?
      By Aerobuilt in forum General Metal Working Machines
      Last Post: 09-01-2006, 12:02 PM
