Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: kit for cnc is this any good
  1. #13
    Feb 2012
    ireland
    Zapp Automation
    what do you all think a bout this kit is anyone using it on here-http://www.zappautomation.co.uk/cnc-driver-kit-four-axis-p-365.html?osCsid=7e11cdd489eda79e36e5ab421e2bc7a4
  2. #14
    Registered doorknob's Avatar
    Jan 2010
    Quote Originally Posted by baldthreads View Post
    I have no direct experience with that kit, however it appears to be quite comparable to the kit linked in post #8 above (with some minor differences).
  3. #15
    Feb 2012
    ireland
    he dosnt sell the z aixes height controler does a plasma really need this
  4. #16
    Feb 2012
    England
    Heh!
    You have three axises X,Y,Z I believe some Plasma tables have two Z axis stepper motors,why I don't know? but on all CNC tables a miniumum of three axises is required.
    The Z axis is not the height its the Y axis thats the height ie in a vertical plain and the Z&X axis in a horizontal plain.
    Should you require another axis then another stepper and driver can be purchased seperatly adding to the kit.
  • #17
    Feb 2012
    ireland
    dose the plasma torch (raise and lower to metal) need a height controler
  • #18
    Feb 2012
    England
    Yes,this is the Y axis stepper,I don't think you can grasp how a CNC works?.
    http://www.youtube.com/watch?v=-cGSlkjMGlE&feature=related]5'x10' Torchmate X with Thermal Dynamics Ultra-Cut 300 and Gas Box.mp4 - YouTube
  • #19
    Jan 2011
    The X and Y axes are the "normal" machine motion around the table, the Z axis is the torch lifting up and down. I've never seen two Z axis motors, just one for the Z and one to move the carriage across the gantry. (can be labeled X or Y depending on how you choose to orient your machine)
    You need a Z axis controller to raise and lower the torch, and you need a torch height controller to adjust the torch-to-work distance during the cut for the best cut quality. Both of these are optional on some entry-level machines. You can cut without them, but cut quality and consumable life will not be as good.
    Carl
  • #20
    Mar 2010
    china
    Quote Originally Posted by HorridHenry View Post
    This is a better kit,its supplied witha bob,better motors and drivers but lacks the 4th motor.
    3 axis Nema23 stepper motor 425oz-in& Drivers CNC controller kit Longs Motor | eBay
    I checked the link, the stepper is from an unknown supplier in China.........
    If u guys want to buy good stepper from china, follow is the No.1 brand in China,
    Shenzhen Baishan Mechatronics Co., Ltd.
    Dont buy cheap items even china manufacturers dont use in this field, then complain china **** product.
    And even a professional CNC controller for plasma&flame cutting is below 1000 USD.....with speed factor to support all stand alone THCs on market. monitor included, u dont need to prepare computer...just plug and run..
    stand alone torch height controller supplier
    http://www.hydcnc.com/en/
  • Page 2 of 2 FirstFirst 12
    1. CNCmachines6090 GOOD OR NO GOOD?
      By CNCZONERAMICO in forum Automation Technology Products
      Last Post: 07-28-2008, 05:25 AM
    2. New Machine Build- any good to use
      By simplicity7790 in forum DIY CNC Router Table Machines
      Last Post: 03-25-2008, 12:34 PM
    3. New EDM, Any Good?
      By Spinner in forum General Waterjet
      Last Post: 10-04-2007, 02:58 PM
    4. Tolerance, how good is good?
      By Aerobuilt in forum General Metal Working Machines
      Last Post: 09-01-2006, 12:02 PM
