We have an old CM-50 cutting machine. We want to set it up with our Torchmate products. Our ideal setup would be to be able to just unplug or disconnect a few electrical wires to change from manual to computer. Does anyone have ideas?
cm-50 is heavy, full of friction and a bear to fix.
I don't think the torchmates dynamic range to control the table will be of any use to you. Plus you would have to retune the drives every time you swapped.
