Results 1 to 5 of 5
Thread: ESAB pcm 1000i help
    Mar 2011
    ESAB pcm 1000i help
    First of all I hope im in the right forum. I picked this plasma cutter up recently and cant seem to find any info on it. I found it in a forclosure property so the price was right. Probly just going to sell it but I dont know what its worth and I would really like to know more about it before I try and sell it. Any help would be great.
    Jan 2008
    If you go to the Esab site you will find info on this unit. Basically it is an 80 Amp inverter based, high frequency start plasma system. Here is a link to the instruction manual.
    http://www.esabna.com/eu/literature/...F-15-224-B.pdf
    Jim Colt Hypertherm
    Mar 2011
    Thanks very much for the help. I couldn't find the info any where. Any idea what this might be worth its in great shape. I'm going to take it to arcet to have it looked over before I do anything with it just to be safe
    Jan 2008
    If it works it is probably worth between $1200 and $1600. It is an early technology inverter plasma system. Does not have the consumable life or the cutting performance oif newer 80 amp systems, but still can be productive. It is not a good candidate for cnc machine use as it is a high frequency start system.
    Jim
    Mar 2011
    Thank u once again. You have been a great help
    1. esab burny 2.5
      By paul h in forum General Waterjet
      Last Post: 05-08-2012, 06:41 AM
    2. Will An ESAB PCM-1000i Work On A CNC Plasma Table?
      By RUN-A-MUCK in forum General Waterjet
      Last Post: 03-23-2011, 10:00 AM
    3. Need Help!- ESAB MEF 44N w/ LAI 400
      By Alex S.A in forum Welding, Brazing, Soldering, Sealing
      Last Post: 10-24-2010, 02:53 AM
    4. Esab Shadow
      By TripleTFab in forum General Waterjet
      Last Post: 03-10-2010, 11:47 AM
    5. Need Help!- esab silhouette 500
      By welder in forum Want To Buy...Need help!
      Last Post: 12-21-2009, 02:02 PM
