Results 1 to 4 of 4
Thread: Plasma Table build
    Jan 2011
    Plasma Table build
    First time poster. I own a welding and repair shop, mostly farm equipment type work. I would like to build a cnc table for plasma cutting and torch use. My problem is I have no clue about cnc. The weld and fab part is not a problem. Machine shop with mill lathe etc is also on site.
    I need to know what type motors, controlers power supplys etc. I will need.
    I plan on making the table with 4 foot by 8 foot capacity.
    In a nut shell if someone can point me to models brands etc of the electronics part, I can figure out the rest. Thanks Mike
    Jan 2008
    Talk to Tom Caudle at CandCNC.com He is your best source for info and components.
    Jim
    Jan 2011
    Thanks I will give him a call. I hope to find a plug and dlay package that is affordable. Looked on ebay most of what I found is in china and I am not.
    Registered millman52's Avatar
    Jan 2006
    USA , West Virginia
    Quote Originally Posted by Kentuckyfarmer View Post
    I am a proud owner of one of www.candcnc.com plaz-pak kits. & if I build again I'll use CandCNC again.
    You might possibly get a bit of initial sticker shock at first glance. However if you take time to compare what you get in one of Tom's kits to components that are comparable in quality +all the wire, cabinet(s) etc. Then all the countless hours to connect, troubleshoot, figuring out what will & will not work together. His stuff is really a pretty good deal & about the only game in town as far as Plug-N-Play goes.
    If it works.....Don't fix it!
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum General Waterjet
    Last Post: 04-08-2011, 12:16 AM
  2. My 4x4 Plasma Table Build
    By unixadm in forum Plasma, EDM and other similar machine Project Log
    Last Post: 06-20-2010, 12:51 AM
  3. new to this and want to build a plasma table
    By poopopo in forum General Waterjet
    Last Post: 10-16-2007, 05:21 PM
  4. 5 x 10 plasma table build
    By DSL PWR in forum Plasma, EDM and other similar machine Project Log
    Last Post: 10-14-2007, 05:09 PM
