I am going to be building or buying a
Cnc Table and I am going to be using the Thermal Dynamics A-120 torch. The question is , Will I be able to run this on a standard 240v house line. Or will I need to get my service upgraded ?
Here's the machines specs :
Quick Specifications:
Gas Flow: 6.7cfm (189 lpm)
Amperage Range: 30-120 Amps, 120 Amps Max., Adjustable
Weight: 63 LBS
Input Power: 208/
230 - 460 Volt,
1 or 3 phase, 50/
60 Hz
Industrial applications: Contractor, heavy Fabrication, manufacturing
Cut Capacity:
3/4 in. (15mm) Maximum Piercing and Cutting Capacity
5/8 in. (10mm) Production Piercing and Cutting Capacity
1.5 in. (25mm) Maximum Edge Start
Duty Cycle: 80% @ 120 Amps
Gas Pressure: 75 PSI
Pilot: Start Cartridge
Torch: SL 100SV with ATC, 180 degree automation
Gas Type: Air
Thanks for the help
