Results 1 to 4 of 4
Thread: NC parallel port?
    Nov 2007
    NC parallel port?
    Hi guys, looking for some guidance here. I am currently in charge of hooking up our CNC machine at work to a PC, and getting the communication working. I have one small glitch that I just noticed however. The laptop that is being set aside as the communication machine, does not have an RS232 port, only a parallel printer port. Is there software I can get that will allow the communication through this port? I will be using Mastercam X3 to generate the gcode if that matters at all. Thank you.
    Dec 2003
    Some software will work with a USB to RS232 converter, they do not run to that much.
    Registered dcoupar's Avatar
    Mar 2003
    As Al said, you can buy a USB to serial converter and communicate through that if you have an open USB port. If not, your laptop probably has a PCMCIA slot. You can get a PCMCIA to serial adapter. They're more expensive than the USB to serial, but I've had better luck with the PCMCIA. Quatech, SIIG, and others have 1 or 2 port serial adapters for $50 - $125. AFAIK, there is no way to communicate through a PC parallel port to a CNC serial port. Don't even hook up a cable between them.
    Nov 2007
    Ok, guess I just needed confirmation of that. I had looked at the Serial slot cards and figured that would be the way it would be in the end. Not a big deal really. I appreciate your help.
  1. C++, Win XP, Parallel Port
    By Zumba in forum Coding
    Last Post: 03-29-2012, 02:12 PM
  2. USB to Parallel port??
    By willio in forum Shopmaster/Shoptask
    Last Post: 11-12-2009, 03:42 PM
  3. parallel port or parallel universe
    By bruno34 in forum Taig Mills & Lathes
    Last Post: 04-15-2009, 11:58 AM
  4. Where's the parallel port?
    By cdlenterprises in forum Mastercam
    Last Post: 01-20-2007, 06:23 PM
  5. Parallel Port
    By Shanghyd in forum Computers and Networking
    Last Post: 11-22-2004, 12:56 PM
