I have most of the specs on Electrocraft/Reliance motors but they had S type DC and AC, the number is normally alot longer than that.
A better description may help.
Hello,
I'm starting to retrofit an old cnc milling center but I have a problem with the servo motors. They are all "Electrocraft s19-3". All i have found on the net is that they are 60 V but no other info.
If some one has more infos about these motors (amps, torque,...),it would help me to choose the correct drivers for them. (I will retrofit it using Mach 3).
Thanks a lot
Patrick Damien
