Originally Posted by
H.O
Hmm....I think you might have misunderstood me... You can feed two drives with the same step and direction signals but it is not advisable to connect two motors to a single drive.
What I meant was something like this:
Pin2 & Pin3: X-Axis S/D
Pin4 & Pin5: Y-Axis S/D
Pin6 & Pin7: Z-Axis S/D
Pin8 & Pin9: A-Axis S/D
Pin14 & Pin16: B-Axis S/D (Slaved, in software, to Y)
Then you have pin1 and pin17, which are outputs as well, available for whatever you like.
However, looking at the UBOB it seems that it only provides 8 "high speed" outputs and that its 'port-stretch feature' inhibits you from using the other outputs as step & direction signals for your fifth drive.... :-( You might want to check with CandCNC though!
/Henrik.
