Results 1 to 7 of 7
Thread: DXFtool can not convert
    Apr 2009
    thailand
    Smile DXFtool can not convert
    Dear Sir,
    I found some problem with dxftool software. I trial demodxftool (periods 30 days)for coreldraw,v.12 before decision purchase. I want use this software to do smoothcurve. when I loaded dxf file to coreldraw and converted with dxftool. It show error as picture. How to solve this problem? Pls advise.
    Sadheers,
    Apr 2009
    thailand
    Post DXFtool can not convert
    Here's the detail of my problem.
    Sadheer
    Attached Thumbnails Attached Thumbnails DXFtool can not convert-1.jpg   DXFtool can not convert-2.jpg
    Attached Files Attached Files
    Mar 2003
    Orange County, California
    Your drawing is bigger than your page size
    Your drawing is bigger than your page size. The drawing must always fit on the CorelDRAW page.
    There is a new version of the DXFTool. Get it from http://www.coreldrawtools.com and try that one. If you continue to experience difficulties you can use the contact form on that website or PM me here. I am the author of this tool.
    -James
    James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
    Apr 2009
    thailand
    Unhappy DXF tool can not convert
    James,
    I am very glad to talk with you. I try changing to fit the corel draw page as your advice. It is not still complete.I don't know what am I doing wrong.After I use dxftool,I see it's not smoothcurve on the sheetcam software. It's possible or not if you will test this example with step by step. Pls see the past example from attached dxf file.
    Pls send the completed dxf file after use dxftool to me.
    Sorry if I disturb you
    Sadheer
    Mar 2003
    Hi Sadheer,
    No disturbance! Support is a part of this business.
    I have sent you a PM. I need to see your CDR file.
    The quality of the results depends on the quality of the artwork. If it is autotraced and has a high node count I can't fix it. The DXFTool does not do curve fitting, it just finds ARC segments in the bezier curves and makes a high quality DXF file that most CAM systems use very well.
    -James
    Apr 2009
    thailand
    DXFtool
    James,
    I just sent CDR and DXF file to you on yesterday. Pls check at your mail
    Sadheer
    Mar 2003
    Where did you get this artwork? If you zoom in on it you will see it is already a series of lines. The DXFTool cannot improve on that.
    A native CorfelDRAW drawing will be smooth curves to begin with. The DXFTool will convert as many of these as possible to arcs. This drawing is all line segments so that is reflected in the DXF export.
    -James
    1. DXFTool V2 for CorelDRAW is released
      By jemmyell in forum Product and Manufacturer Announcements
      Last Post: 03-08-2009, 09:43 PM
    2. Convert BT 40 to Cat 40
      By dafowfidy in forum Haas Mills
      Last Post: 01-16-2009, 10:57 PM
    3. Convert from JPG to DXF
      By chakaloso in forum General Metal Working Machines
      Last Post: 03-10-2007, 03:31 AM
    4. Can I convert this?
      By Crazy Phantom in forum Benchtop Machines
      Last Post: 12-13-2005, 12:47 AM
    5. How did you convert
      By CNCadmin in forum Benchtop Machines
      Last Post: 03-18-2003, 10:42 AM
