Try going to
http://www.haascnc.com/training/Misc...20on%20Web.pdf
and download the free program generator. It allows you to quickly generate the canned cycles and the code to turn the part.
Let us know if you need more help.
Stu
iam jujst starting out on one and if i can get any help its appreciated.
also a turning program too .. what it would look like.
Any stock size is fine ,, i want to see how to do it in a canned cycle
Try going to
Stu
h
Are you programming a Haas machine or a Hass machine?, you should be as specific as possible, as there may be subtle differences between these machines, and the NC code may not work properly.![]()
here's the thing. I am telling you right now I don't claim to be an expert in long hand programming however I am about to receive my A.A.S. degree in machining tech and my emphasis is in CNC programming and operating. From personal experience I have found as a newbie in the CNC world it is far easier to program a facing cut long hand than it is to do in a canned cycle, only because, how many passes do you need to make for a facing operation? one, two usually...I.E.
( PREPARATORY COMMANDS GO HERE)
G00 X1.5 Z-.010
G01 X-.005 ( FIRST PASS)
G00 Z.1
X1.5
Z-.020
G01 X-.005 (SECOND PASS)
And so on and so on. this is just for me an easier way of building and reading a program. because at my place of work and at school we do not have issues with information storage.
I hope this info helps you, and I did not miss the point. thanks, joe
I went to web site but when i click on link to down load it doesnt work .. would any one possibly have this ? allready ?/ that can send m a e mail of it ?? i also called the company 800 phone number AND THEY SAID THEY COULDNT HELP
try CNCsimulator. I think the web address is www.CNCsimulator.com it has a basic simulation program you can use to do basic verification programming. howeeer if you are serious about verifying your stuff you can buy cimco edit5 with the lathe package thats what we use at work and at school
As it says at the top this program faces and chamfers the end of a piece of stock. If you copy this and load it into a Haas lathe you can watch in in Graphics.
O00010 (FACE&CHAMFER)
N1 G20 G40 G80 G99 G61 G97
N2 G53 G00 X-2. Z-15.
N3 G50 S1800 (max spindle speed)
N4 T101
N5 S1000 M03 (starting spindle speed)
N7 G00 X5.79 Z2. M08 (move to a safe distance for start)
N8 G00 X5.79 Z0.15 (move to actual starting distance)
N8 G96 S1600 (set constant surface speed CSS at 1600FPM for aluminum)
N9 G72 P10 Q18 D0.03 U0.004 W0.004 F0.005 (face in .03 increments leave 0.004 for clean up)
N10 G00 X5.78 Z0.
N11 G01 X3.5 F0.004
N13 X2.5
N14 X0.
N15
N16
N17
N18
N19 G70 P10 Q18 (take finish cut)
N20 G97 G00 Z6.
N21
N22 M30
i guess at this point I still believe that z would be at the end of the part and negitive is cutting into the part I guess I'm not sure why this program is cutting at z-15.and dthe x is usualy programed off the center or the diameter so that seema ok. unless you mean that your g54 is setup off machine zero and then I think I would understsnd but then you would have to calculste that distance in your program. I guess to summ it all up I may not haver the experience that others may have. I can say that I have run a haas and fanuc controlers. please dont ask me to identify the model numbers. thanks joe please excuse the spelling it is now time to do honey doos
You are referring to the G53 X-2. Z-15.0 line.
G53 is machine coordinates so in fact this move takes the tool 15" from machine home on the Z and 2" away on the X.
This program was written for a Haas TL2 and I use the G53 command instead of G28; G28 would take the machine all the way home which is 40 inches away from the chuck.
The actual cutting moves start at line N7.
The tool offsets are to the finished end of the part which is why line N8 has the tool positioned at Z0.15 just before the G72 canned cycle.
The G72 faces the part down to Z0.0.
Most times you would not need to take off this much material when facing.
bobrob,
The link appears to have changed. Try this one "ftp://haascnc.net/Training/" then download the folder QC.
Rgds,
John B
tHANK YOU I WILL GIVE THIS A TRY TOMORROW WHEN I GO IN TO WORK ..
