Not sure what you mean by "Data Sheet". But I do have a DahLih with the 11M control, not sure about the 1350, but I can look in the morning. But I'm not clear on what you mean by data sheet.
We have a Dah Lih 1350 mill that had an interrupted tool change. The operator spent about 45 minutes doing the panic change things around routine before letting me know...After I fixed the tool changer that was stuck at the 70 deg position it would change tools but not remember the order correctly. It picks a different tool pot each call.
It has an 11m control on it but I have no Data Sheet for the PMC parameters. I have compared it to a 1020 with an 11m and they are similiar with a few differences.
If anyone has the Data Sheets for the 1350 could you please contact me .
Curt
And yes it is a MCV-1350, now I just need to know what you need.
Thanks for the reply. It is a sheet with all the PMC settings.
ie: PC: Keep Relay Data Table Data#1 PC: Timer 1
PC:Counter 1 Data Table Control Data
If you could get me those data parameters it would be greatly appreciated.
it say too much text, if you pm me your e-mail address, I'll send it in word format.
Virg
lets try it this way,
DAHLIH #1 BACK-UP DATE 1/28/09
FANUC SERIES 11 PMC DATA
TIMER
ADDRESS NUMBER DATA
T00 01 500
T02 02 500
T04 03 0
T06 04 5000
T08 05 5000
T10 06 5000
T12 07 1000
T14 08 1000
T16 09 1000
T18 10 0
T20 11 5000
T22 12 5000
T24 13 0
T26 14 10000
T28 15 10000
T30 16 0
T32 17 200
T34 18 0
T36 19 1000
T38 20 1000
T40 21 0
T42 22 200
T44 23 200
T46 24 0
T48 25 0
T50 26 0
T52 27 0
T54 28 0
T56 29 0
T58 30 0
T60 31 0
T62 32 0
T64 33 0
T66 34 0
T68 35 0
T70 36 0
T72 37 0
T74 38 0
T76 39 0
T78 40 0
COUNTER
NUMBER ADDRESS PRESET CURRENT
01 C00 23 15
02 C04 0 0
03 C08 0 0
04 C12 0 0
05 C16 0 0
06 C20 0 0
07 C24 0 0
08 C28 0 0
09 C32 0 0
10 C36 0 0
11 C40 0 0
12 C44 0 0
13 C48 0 0
14 C52 0 0
15 C56 0 0
16 C60 0 0
17 C64 0 0
18 C68 0 0
19 C72 0 0
20 C76 0 0
KEEPRLY
NUMBER ADDRESS DATA
01 K00 10000101
02 K01 10000010
03 K02 00000100
04 K03 00000000
05 K04 0
06 K05 0
07 K06 0
08 K07 0
09 K08 0
10 K09 0
11 K10 0
12 K11 0
13 K12 0
14 K13 0
15 K14 0
16 K15 0
17 K16 0
18 K 0
19 K 0
[DATA TABLE CONTROL DATA
NUMBER ADDRESS PARAMETER # OF DATA OFFSET SPECIAL TABLE
01 D0000 1
02 D0002 00000001 25 0000 0 3
03
04
05
06
07
08
09
10
DATA TABLE DATA #001
NUMBER ADDRESS DATA
0000 D0010 3
0001 D0011 12
0002 D0012 23
0003 D0013 15
0004 D0014 6
0005 D0015 20
0006 D0016 4
0007 D0017 2
0008 D0018 7
0009 D0019 19
0010 D0020 1
0011 D0021 21
0012 D0022 25
0013 D0023 5
0014 D0024 16
0015 D0025 9
0016 D0026 11
0017 D0027 10
0018 D0028 22
0019 D0029 24
0020 D0030 18
0021 D0031 8
0022 D0032 13
0023 D0033 17
0024 D0034 14
DATA TABLE DATA #002
NUMBER ADDRESS DATA NUMBER ADDRESS
0 D0036 0 19 D1314
1 D1278 0 20 D1316
2 D1280 0 21 D1318
3 D1282 0 22 D1320
4 D1284 0 23 D1322
5 D1286 0 24 D1324
6 D1288 0 25 D1326
7 D1290 0 26 D1328
8 D1292 0 27 D1330
9 D1294 0 28 D1332
10 D1296 0 29 D1334
11 D1298 0
12 D1300 0
13 D1302 0
14 D1304 0
15 D1306 0
16 D1308 0
17 D1310 0
18 D1312 0
I hope thats usable, and helpful.
Virg
Thank you!!! I will try them out and let you know how it worked out.
Thanks again!!!
Curt
One parameter is different than yours but it is an option. The other ones worked like a charm.
Thank You Very Much For your time to post those paraters!!!!
Hope it is OK to continue the thread on the same basis. I bought a Dah Lih MCV 510 which apparently has the same or similar errors. You can download the tool manually, but doing it under programs that are taking the wrong tool. What do you think.
Unfortunately I can not check your answers for my machine is in storage until the spring but I'd love to have a good base to try when I get home my machine.
I have seen the machine in operation before I bought it, so I saw that tool changer operated manually. The system is Fanuc OM-F. My first machine with Fanuc.
Grateful for answers.
ps
Fala_Man is it ok to continue the tread?
ds
