G41 and G42 allow you to program the part profile, without the bother of calculating the cutter centerline coordinates. Or, if you program the cutter centerline, G41 and G42 allow you to adjust for oversize or undersize cutters. G41 will offset the tool to the left of the programmed path by the amount (+/-) stored in the offset register. G42 will offset the tool to the right of the programmed path.
LinkBack URL
About LinkBacks
