Hi there,
From the info you posted, you will need a 3D design applicatiion of some kind, and a means to derive gcode from the designs you create.
There are a plethora of applications that can do this kind of work. You mention cost is an issue. It is more than possible to produce excellent quality work using entirely FREE software.
I would recommend Gmax as design software and the CNC_Toolkit plugin for generating up to 3, 4, or 5 axis gcode. This is based on AutoCAD and 3DS max and has excellent abilities and pedigree. It's entirely FREE, legal and can accomodate any 2D or 3D design work and the majority of gcoding tasks..
CamBam is another utility you might like to checkout. CamBam has recently been released in commercial form, but 10bulls is still distributing the beta version for FREE. This has many useful functions including 2D and 3D design, gcoding from 3D models and also generating gcode from bitmap sources. It could easily be applied to the kind of work you mention.
To be honest there are too many free options to list in a post like this, which is why I set up a website at http://cnc4free.org to better inform the CNC community of the available FOC options
It might be worth taking a look.
hope this helps
Danny (aka Yohudi)
LinkBack URL
About LinkBacks
