Results 1 to 2 of 2
Thread: Bandit Control
    Aug 2008
    Bandit Control
    Looking for a Bandit Control. Rigger dropped mine off truck! I'm retired machinist and grew up with this control. Too old to change. Too much damage to consider repair.
    Thanks,
    Robert..........toppik@aol.com
    Moderator HuFlungDung's Avatar
    Mar 2003
    To old to change? In the case of a Bandit, that's like being in too much pain to take a pain reliever
    You may not have heard of 'The Shadow', but that is a relatively modern version of the old Bandit. Its not 100% interchangeable with Bandit code, but close. I think rad comp doesn't work as well with the Shadow as the Bandit, not sure if you used that a lot. They also incorporated standard work shifts in the Shadow, so that means that the G58 save position command is no longer available.
    The Shadow is available from Control solutions in Bozeman. One thing it has is 10000 line memory compared to the Bandit's 1000 'word' memory.
    The reason I'm suggesting this, is that perhaps an old restored and working Bandit might be quite expensive to come by.
  1. Bandit Control
    By DieGuy in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 02-05-2011, 09:17 PM
  2. Shizouka w/Bandit 4 control / to buy or not??
    By teamjnz in forum Knee Vertical Mills
    Last Post: 09-29-2008, 04:01 AM
  3. Hardging HC with Bandit control
    By Kevin Taylor in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 05-10-2008, 12:24 AM
  4. Mastercam to Bandit control
    By jjclear in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 12-21-2007, 11:21 AM
  5. Bandit Control ?
    By jdelaney44 in forum Bridgeport and Hardinge Mills
    Last Post: 03-06-2005, 09:36 PM
