Al,
Thanks for the link. I hadn't looked at this software before.
I use NcPlot to double check Gcode before run. Does this program do the same thing? Does it do something not provided by NcPlot?
Karl
For those using the FREE Microtech CNC simulator, http://www.cncsimulator.com/
There is an upgrade to ver 4.53f.
This fixes a few bugs and now has canned programs for drilling etc,
Also Fanuc programs and sub program examples, and some heidenhain files.
I found, however, I had to remove all trace of the existing version, otherwise the older version would run after I loaded the upgrade?
Al,
Karl
I have never used NCplot so I can't compare it.
So far it has worked for me, with some of the bugs ironed out and the new canned features it should be even better, for what I do , anyway.
