Results 1 to 9 of 9
Thread: shizuka cnc mill, Yasnac contorller
    May 2008
    I'm a newbe with a question.
    I have a shizuka cnc mill with a Yasnac 3000G controller. There is a GRECO MTIC installed also. I have MasterCam on a dedicated computer for the mill. I'm told by Greco that I need a software called WinDnc they sell for about $1000 to make everything i have work together.
    Since this is a hobby shop setup, i don't want to spend that kind of money. Does anyone have any other suggestions on how to get my MasterCam design over to my Shizuka CNC Mill.
    Thanks for the help, Regards, Chuck
    Mar 2007
    Chuck,
    You should be able to use a program called Hyper Terminal that is
    included with Windows XP. (program files, accessories).I do not know how to set it up but maybe some else here on this forum does.
    Al
    May 2008
    I looked at hyper terminal and it wants a phone number for dialing into the device (milling machine).
    Don't thinks this is going to get me there.
    REgards, Chuck
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    It can be done with hyperterminal. And there are other free programs out there. For us mear mortals, setting these up is so hard that the $1K program from your vendor looks cheap.
    Karl
    Banned
    Jan 2006
    Seattle
    It can be done with Mastercam's built-in communications too.
    May 2008
    Mike, If i use MasterCam's built in communications do i go straight to the Yasnac controller or to the Greco MTIC?
    Regards, Chuck
    Dec 2003
    Hyperterminal is a pain to set up, I have a copy of Terminal that came with windows 3.1. it is much better for this and will run under later windows.
    Also I believe Cadem Lite is still available free from their site, it is specifically for CNC.
    May 2008
    Quote Originally Posted by Al_The_Man View Post
    Al, if I use windows 3.1 Hyperterminal or Cadem lite, do i go through the Greco MTIC or go directly to the Yasnac 3000G controller.
    Thanks,
    Chuck
    Banned
    Jan 2006
    Seattle
    chuckbuck,
    you go from the computer to the Greco MTIC.
    1. Help on Yasnac 2000G
      By ktb100 in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 07-05-2008, 10:31 AM
    2. %$@*^!! Yasnac on a Hitachi
      By Paul in OK in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 04-07-2008, 10:51 AM
    3. yasnac J 100 M
      By Furlan in forum Manual Machining Tooling
      Last Post: 11-17-2007, 10:55 AM
    4. Yasnac i80 error 102
      By Boring Life in forum Fanuc
      Last Post: 04-08-2006, 07:05 PM
    5. Yasnac I80
      By Gitanes in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 11-24-2005, 12:00 AM
