can you be more percific what you want?
I am looking for programs,canned cycles...etc That are written for a Fanuc OM control.I really need a pocket milling program.Any and all help would be greatly appreciated! THANK YOU...
I am looking for a pocket program to mill a 1 inch diameter hole 1 inch deep into a piece of steel. I am not familiar with this control and when I write the program the way I am used to it just errors out. it is a fanuc om control on a daewoo vmc. I am just looking for a few programs that are proven on the same type of control to see what I am missing.
:4001 (HELICAL)
G21 G40 G80 G90
G0 G54 G90 X0 Y0 S2000 M3
G43 Z5.H3
#100 =-20.(FINISH DEPTH)
#101 =10.(RADIUS OF CUTTER)
#102 =30.(HOLE DIAMETER)
#103 =150 (FEEDRATE)
#104 =5.(PECKING DEPTH)
#105 =0 (START DEPTH)
#106 =#104
#107 =ABS[#100 ]/#104 (NUMBER OF PASSES)
#107 =ROUND[#107 ]
#102 =#102/2.
#102 =#102-#101
G1 Z#105 F500
G1 X#102
#1 =1
WHILE[#1 LE#107 ]DO1
G3 I-#102 Z[#105-[#104*#1 ]]
#1 =#1+1
END1
G3 I-#102
G0 X0 Y0
N10 Z10.
G91 G28 Z0
M30
This is in metric but will work on imperial, hope it helps
I 'm fresher,nice to meet you
