I have an Anilam series M controller. When I run a program, it is now stopping at each step and waits for no reason. The servos rotate back and forth, maybe 5 degrees. I am able to run the programs by hitting the "search" button and than "start". I ran diagnostics and received no errors.
I started having this problem after using the ARC command. I don't know if this is related. I am now having this problem in all programs, even simple drill programs.
