Results 1 to 8 of 8
Thread: Text Programs?
    Oct 2007
    UK
    Text Programs?
    Hello,
    Could I have your suggestions for an application, preferably free or very cheap, that I can use to create gcode from text.
    I need to create some text that is warped, ie. goes round in an arc.
    Any suggestions?
    Thanks,
    Nick.
    Jun 2006
    what type text ( font) height. also what arc do you need it go around? on top or bottom of arc? I can do it for free. in DWG or DXF or IGES format..
    Oct 2007
    UK
    Laserboy,
    Thanks for your offer, but its several bits of text I need to do from time to time.
    What application are you using to output the text in DXF?
    Nick.
    Registered CNCRim's Avatar
    Feb 2006
    Hmm, Deskengrave is free for normal text straight, arc flat surface , but wraped text need more work..... I recommned WinEngraver sell on Travel.
    Oct 2007
    UK
    Hello,
    I found Deskengrave and its almost what I need. I can get the text to go around in a clockwise direction, but I also need an anticlockwise also, is there a way of doing that with Deskengrave?
    I couldnt find anything about Winengraver, do you have a link to a site?
    Thanks,
    Nick.
    Registered dcoupar's Avatar
    Mar 2003
    I've used MillWrite successfuly.
    http://members.aol.com/m9685123/Mdemo.htm
    Oct 2007
    UK
    Hello,
    Still on the look out for a simple text engraving program.
    Deskengrave would be great if I could figure out how to do text anti-clock.
    Winengraver - Can't find it
    Millwrite - Doesn't appear to do text in an arc/circle.
    Nick.
    Oct 2007
    UK
    OK, problem solved.
    Thanks for all your help, especially newtexas2006.
    Deskengrave with a negative radius prints anti-clock.
    Thanks,
    Nick.
    1. 3D text
      By Deco_2000 in forum SolidEdge
      Last Post: 10-11-2007, 04:23 PM
    2. text
      By marty7001 in forum BobCad-Cam
      Last Post: 05-31-2007, 03:26 PM
    3. Need Text Help
      By becikeja in forum BobCad-Cam
      Last Post: 11-12-2006, 12:54 AM
    4. Text programs
      By Super G in forum General CAM Discussion
      Last Post: 11-24-2003, 10:36 AM
    5. Text
      By Bigfoot1 in forum OneCNC
      Last Post: 04-04-2003, 10:06 PM
