Results 1 to 2 of 2
Thread: Problem with stepper motor stuttering
    Sep 2007
    I'd like to start by saying I am a noob at this so forgive me if I use incorrect terminology.
    I recently bought a Hobby CNC package to go on my taig tabletop mill. I am having problems with the stepper motor stuttering and just outright stopping, however its evident its still trying to turn. I would say it sounds like classic binding problems, however it still does it even when the motor is in hand.
    The stepper motors that came in the kit are
    23-305-DS8A
    4.2v 3a 1.4r
    The software is Mach3
    The controller board is also from HobbyCNC and came in the kit.
    Any ideas would be greatly appreciated
    Keith
    Jan 2008
    sounds like...
    if it happens as you turn it by hand, if that is what you meant then I'de say it's a motor hardware problem otherwise check this out - http://www.machsupport.com/forum/ind...ic,1187.0.html
    You access 'motor tuning' in the config menu. Hope it helps.
  1. Stepper motor controller problem
    By Martincho in forum Stepper Motors and Drives
    Last Post: 01-04-2008, 12:32 PM
  2. 201 buzzing and stuttering
    By quamit in forum Gecko Drives
    Last Post: 09-18-2007, 07:45 PM
  3. Does anyone have stepper motor power supply problem?
    By david_geng in forum Syil Products
    Last Post: 09-04-2007, 02:02 PM
  4. stuttering stepper motor
    By rustranch in forum DIY CNC Router Table Machines
    Last Post: 08-31-2004, 09:06 PM
  5. Replies: 5
    Last Post: 08-31-2004, 09:16 AM
