Hello Jinx222
Have a look at the parameter screen under I think from memory it is parameter 7 on the "Word" page. The setting is in minutes with a minimum setting of 1 minute.
Will look in the book when I get back to work on Monday.
Cheers
Brian.
Anyone knows which parameter turns off Power Save Alarm (repeats every 10 or 15 minutes) on Okuma LB15 with OSP5000L control ?
Hello Jinx222
Cheers
Brian.
Hello Jinx
Finally remembered to look up the parameter that relates to the power save timer!
I had guessed it correctly in the first instance...
It is Parameter 7 on the Optional Parameter (Word) page.
Setting is in minutes min=0 max=10000
Regards
Brian.
