Results 1 to 7 of 7
Thread: lathe index mark sensor
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    I'm needing a sensor to mark the exact same spot on the lathe spindle once per turn. Its used for threading as the index mark. My control vendor, Camsoft, recommends a rocker switch and cam type arrangement. It would be just like the old fashioned points in a gasoline engine.
    I thought of just using engine points, but I don't think they'd last long in a lathe. And running backward would probably break them.
    I'm not finding a part like this. Any suggestions?
    Karl
    Oct 2003
    TEXAS
    Karl,
    We spoke on the phone at the end of March about this subjectand indicated we have a module that will do what you describe. You then posted in the CamSoft Forum your circuits to accomplish this task. What are you really trying to accomplish.
    n174k
    Mar 2004
    Dassel,MN,USA
    I probably should have bought your item. My home designed module to amplify the index pulse does not work well at high speed. I'm guessing its a scanning problem, the index pulse can come between scans???? Not sure here, but performance is not acceptable.
    Anyway, I didn't find a mechanical switch that I thought would be reliable. So, I'm installing a slot sensor and will be hooking this up to a high speed Opto 22 input. The sensor has just microseconds of responce time. I just finished the mechanical part of the slot today. The sensor will stay on for 1/2 of a full spindle revolution.
    This should give a very accurate timing mark to Camsoft. I'll know for sure in a few days.
    I'll paln on posting again to the thread on your marker pulse about my woes with the home made version. And what i did to sovle the issue.
    Karl
    Oct 2003
    TEXAS
    Karl,
    Our module does not care whether the encoder is single ended or differential output and has been tested up to 4000 rpm of the spindle and did not miss a revolution. The threads repeat perfectly on 4 pitch threads at 400 rpm running over the same part 10 times as reported this week from my customer threading pipe couplings. He has successfully run up to 800 rpm with 8 pitch threads in another production run. This is a Motch VTL 24" chuck with CamSoft CNC Pro control system installed last December.
    n174k
    Oct 2003
    TEXAS
    Karl,
    This module only requires a spindle mounted encoder with a 1:1 ratio.
    n174k
    Mar 2004
    Dassel,MN,USA
    Quote Originally Posted by n174k View Post
    Karl,
    n174k
    Don't rub it in <VERY BIG GRIN>
    That "Not invented here" syndrome has really cost me big time on this job. Your module should be required equipment on any Camsoft CNC lathe. The other option, using VIRTINDEX, is not for any serious use.
    Karl
    Mar 2007
    Quote Originally Posted by Karl_T View Post
    Karl
    Look into electronic ingnition sensors with matching control unit if your going to try automotive components. They are no contact. They are cheap in the junk yard. There is also a company that makes a retrofit to go from points to trigerless ignition. They use a light beam to trigger the coil. Its UNI...... something , call an auto-parts store. It's a common upgrade...
    not sure if the precision is going to be repeatable to the needed tolerance??? Or if the output is compatible.....
    1. CNC for mini-lathe by SIEG (Micro-mark, HF, etc)
      By JohnELMDAS in forum Mini Lathe
      Last Post: 01-23-2008, 08:07 PM
    2. Taig / Digispeed XL spindle index sensor
      By Dfennell in forum Taig Mills & Lathes
      Last Post: 01-02-2007, 12:23 AM
    3. Index Cnc Lathe
      By hitachi salty in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 08-31-2006, 01:54 PM
    4. lathe tool eye or touch sensor
      By Karl_T in forum CamSoft Products
      Last Post: 04-26-2006, 07:15 AM
    5. Micro Mark
      By xa_shall in forum Mini Lathe
      Last Post: 11-10-2005, 05:24 PM
