Results 1 to 6 of 6
Thread: Error Axes Drive Fault on CHNC I
    Feb 2007
    MEXICO
    Hi!
    Do you Know what I need do with the CHNC I error Axes Drive Fault
    Axes Not Enabled
    Axes Drive Fault
    error 6011
    I Cheched the Tachometer and this is ok!
    Nov 2006
    Scotland
    What drives does it have?
    Mark.
    Feb 2007
    MEXICO
    I have a problem in this moment in X drive
    I clean the four bruches of servo, this had too dirty
    I don't know what more need do.
    can you advise me?
    the machine had z and x drive.
    Have a Nice day
    Nov 2006
    Scotland
    The drive will not enable because it has a fault and is not giving the cnc control the "drive healthy" signal.
    When you look at the axis drives can you see what make they are and is there any red lights on them?
    Mark.
    Feb 2007
    MEXICO
    yes, the red light is present, the machine turn on (singing) for 5 to 10 second and the red ligth turn on.
    Have a Nice day
    Feb 2007
    MEXICO
    I fixed it, the problem was in the motor X, this had burned the brushes area.
    I replace the motor and now is working perfectly.
    Have a Nice day
    1. Dynapath Fault Error
      By buba447 in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 02-15-2012, 10:01 PM
    2. Need drive for CHNC spindle motor
      By rkdygert in forum Servo Motors and Drives
      Last Post: 01-27-2007, 01:03 AM
    3. Axis drive fault/off error message
      By Healey in forum Bridgeport and Hardinge Mills
      Last Post: 11-08-2006, 04:49 PM
