We've had very good luck with Procomm Plus.
Correct cable wire and COM settings are very crucial. Make sure you check them down to a T. If all is set correctly, you may even use Window Terminal to load your program.
PS: Is your Dyna a PC based controller?
LinkBack URL
About LinkBacks
