First of all, I would like to say that I am sorry to hear that your machine has died such a terrible, tragic death.Originally Posted by CNC_Newbi
I think that you may have 3 options:
Option 1 is that you know of an identical machine with the same electronic controls (which are guaranteed to be operational) and replace all defective circuit boards. (Will you blow additional circuit boards? How long will these other boards continue to function?)
Option 2 is to get a field service tech to troubleshoot the defective components and repair the defective boards. (Worst and most expensive Option)
In my opinion, I think the least expensive route is Option 3 as follows:
Replace the controls with Gecko 320 or 340 Servo drives. (Cost approx. $134.00 each) You can use your existing servo's and most likely the encoders, HOWEVER, you would have to replace the unit power supply. (About $250.00 unless you build your own for about $100.00)
Use a computer running Mach software and a parallel port breakout board ($25.00 - $135.00 depending on preference) which will accept the tach inputs for spindle speed control.
The integration issue depends upon your ability to read wiring diagrams, to perform some wiring tasks, to set up the computer and the Mach software, and to do some possible troubleshooting if everything does not work the first time around.
However, the wiring of the drives, encoders (provided you have schematic or know which wires are +5V, common, A phase, B phase) should not be a difficult task since there are wiring diagrams for the drives, servos, and encoders on this site.
This is just my opinion. Good Luck.
LinkBack URL
About LinkBacks
