Hi all i am trying to dump the programs out of my T1 controll mazak with no joy.
when you go to the punch page you get a list of option like
1 machine prog
2 tool info
3 etc
4 etc
and so on when i hit punch out it will not let me select any of these.
It does on recieve but not punch.
is there a parameter i should select to set it it to use rs232 or something else.
cheers in advance for any help.
Sorted it out just incase any 1 esle wants or needs to know.
i managed to do it just setting the param as above.
With this control you cannot select just programs when you dump out it dumps everything from parameters to offsets the lot. this is no big deal as each prog on our machine is very small.
You also need i belive a mazacam or similar software to actually read the progs once dumped if you use a third party program it might take it but not in any sort of state that you can read.
