My school has mastercam X and we want to tranfer the nc code to the dome by tecno inc. First Does any one use Tecno, if so I got the file type to .nci and can run the other programs that were already converted and run before but I can not get the program I want to run to run. any help would be grately apreciated.
Thanx
Cadfish
cadfish
http://www.burgiengineers.com/
There should be a postprocessor for Techno if the machine and MasterCAM came as 1. The postprocessor is MPTECHNO and should be in the list to choose from when you go to post your code and are given the option to change the post to whatever you desire. If it helps at all the file extension needed for Techno is .NCD. If you need more help PM me and I can see if I can e-mail the PP to you in the near future.
Dan Brinkman
