i guess this question might sound a lil silly to some a ya guys but,
i really couldnt find an answer anywhere on this forum nore elsewere
so i decided to waste some a yall guys precious time :
how will mach3 for instance know the exact size of the endmill i'm using(i'm talking bout the length since i have normal endmills as well as extended ones
wich are the same diameter ofcourse?
or what size drillchuck i got so it will be able to set the Záxis to the correct height.
is this manually filled in a surtain field in the prog.interface or does your
cam software calculate what kind a cutters you should use as it produces your g-codes ?
if my question aint all clear i'ld be happy to refraze.
