How thick of a material you can cut is a function of the power of your laser and how fast you move, what material you are cutting and it's reflecivity to a degree.
The software isn't going to turn your 4mm machine into a 2cm machine.
To do that you need to have more power, "softer" material, less reflecivity, slower feed, etc.
Far as I know software will not give you more watts unless you have some sort of software lock to enable some function or wattage range. Never heard of that on a laser engraver though.
LinkBack URL
About LinkBacks
