Results 1 to 3 of 3
Thread: xyz proturn lx2 slave
    Nov 2005
    England
    I have an xyz proturn 410 with LX2 control.
    It had servo tripping issues, then I moved it in to our new workshop.
    Now after loading LX2 it errors saying SWI hardware key busy or not attached.
    If I enter service code 33, there is nothing after SLAVE.
    xyz machine tools say it cannot find or read the slave but I do not know whether the slave is a computer card, chip or what?
    Any help appreciated.
    If all else fails I will probably change the controller but would rather get this working if economically possible.
    Mar 2012
    UK
    Hi have you still got the machine or have you now sold it on/did you fix it in the end? we are looking at buying one and wandered if this was the same machine (simular problems)
    Nov 2005
    England
    Still got the machine, open to offers, but would like to get it working fully.
    Mechanically in good condition, just need to sort out the control.
    Am starting to look at the possibility of using mach 3 via a motion control interface with usb connection, but still got more to learn.
    All the LX2 software appears to be working fine, just cannot get the servos to power up due to not being able to find the slave.
    Thanks for the reply.
    regards
    Edward
  1. to slave or not to slave
    By stef_d in forum DIY CNC Router Table Machines
    Last Post: 11-27-2009, 12:52 PM
  2. Slave an axis?
    By ger21 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-02-2009, 11:44 PM
  3. Slave drives X & A
    By joecnc2006 in forum Mach Mill
    Last Post: 11-21-2006, 09:23 PM
  4. Need to slave slave A axis to B axis..
    By foam27 in forum Mach Mill
    Last Post: 07-03-2006, 10:58 PM
  5. Slave axis
    By walter in forum Mach Software (ArtSoft software)
    Last Post: 01-08-2006, 07:47 PM
