Results 1 to 2 of 2
Thread: Need Help setting/changing parameters
    Apr 2012
    Hello,
    I have a 1989 Mori Seiki SL20 with a Yasnac control. The parameters start at N6000. My question is, how do you edit the incorrect parameters? Also parameters 6030-6049 are gone. Thanks for your help. Machine seems to be working fine, other than when a G76 is called up. It will run through the threading cycle, but the feedrate is way too slow.
    Apr 2012
    To edit the 6000 parameters you must be in MDI mode the system switch on the back control door must be set to #7 . Once you cursor to the selected parameter you then press the Insert key which will move the cursor to the right, then edit as required. You must use the insert key again when you change pages. For the 6030 parameters you need to put system switch in position #4 and then exit & re-enter the parameter page.
    Hope this helped..
    Good Luck
  1. Replies: 14
    Last Post: 12-07-2012, 02:04 PM
  2. Changing parameters in program?
    By chucker in forum Fanuc
    Last Post: 05-03-2011, 09:41 AM
  3. Changing Parameters in the Program
    By danrudolph in forum CNC Swiss Screw Machines
    Last Post: 10-21-2010, 05:03 AM
  4. Methods of changing parameters
    By sinha_nsit in forum Fanuc
    Last Post: 10-05-2009, 09:41 AM
  5. Need Help!- Changing S/N setting 26 to cancel alarm 144
    By robard in forum Haas Mills
    Last Post: 03-14-2009, 12:32 PM
