Results 1 to 3 of 3
Thread: Heidenhain TNC 426
    Dec 2004
    South Africa
    Heidenhain TNC 426
    I am looking at a machine with a Heidenhain TNC 426 control on it.
    The machine seems OK, but i am not familiar with the pro's and cons of the control. Does anybody know the heidenhain TNC 426 family of controls? Can parts for them still be obtained?
    On one spec sheet that i saw it seems like the control is a conversational unit that does not require the user to use G gode. I use only Gcode to program at the moment and also use mastercam and bob cad to generate code so i would not like to switch to anything other than gcode.
    Would this machine still un gcode in the background?
    Would you buy a machine with this control?
    Thank you
    Pieter
    Oct 2009
    uk
    Hi
    Hi this control can be used in g code but you will find the user control much simpler than you imagine the canned cycles are straight forward none of this silly g code stuff were you have to cancel with g code then engage with another, you also can switch between incremental and absoulute by pressing I key next to the poler P key, rl comp rr comp or no comp again is asked for on each line as you programme, use datum shift to set up, long term you will find this an better way to run your machine, ie- leaving one set up on your bed where ever and another one or more some were else, and for god sake don,t by a hass with g codeing its totally rubbish,
    i guess if you want i can send you a prog with every set up you will ever need its my progs template.
    Dec 2004
    South Africa
    Thank you Philip,
    I take it that you would recommend the heidenhain then?
    Have you ever had trouble with yours and were you able to get parts or get it fixed easily?
    I am scared of going for a control with limited support, or very high repair cost and then getting stuck with a lump of iron that is not worth the money it takes to keep the control alive.
    Is it a good control for 2d and some 3d contouring?
  1. HEIDENHAIN TNC 430
    By aleks.4 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-23-2010, 08:48 AM
  2. HEIDENHAIN-ISO
    By shafter in forum Bridgeport and Hardinge Mills
    Last Post: 03-27-2010, 02:44 PM
  3. Need Heidenhain help
    By Kevin77 in forum Bridgeport and Hardinge Mills
    Last Post: 10-13-2009, 08:02 AM
  4. Heidenhain TNC 155
    By davesnd in forum Bridgeport and Hardinge Mills
    Last Post: 06-23-2009, 11:32 PM
  5. Problem- HEIDENHAIN TNC 145
    By zknives in forum Bridgeport and Hardinge Mills
    Last Post: 07-23-2008, 09:43 PM
