Results 1 to 3 of 3
Thread: Shopmill Helical Insertion
    Oct 2007
    UK
    Hi guy's,
    Could someone please explain Shopmill Helical Insertion?
    I am unsure what EP (Insertion Pitch) or ER (Insertion Radius) means.
    I have seen this 'In action'. The EP was 7, and the ER was 2.
    I noticed the cutter cut -7.0mm and then appeared to step out, cut a complete radius, and then continue downwards in the same manner to the -75mm it was set to.
    May 2004
    This avoids the tool plunging to the full -75 mm and allows the tool to cut its own chip relief on the way down. Normally would be used for a pocketing operation.
    http://www.kirkcon.com/
    Oct 2007
    UK
    Thanks for the quick reply.
    So if I understand you correctly:
    If I programmed a 40mm diameter pocket, 40mm deep and set the EP to 5 and the ER to 2. The cutter would cut a 38mm diameter pocket 5mm deep, then step out to 40mm, do a complete 360, and then continue downwards in this manner?
  1. Shopmill - please help
    By TotalRookie in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 02-27-2012, 05:50 PM
  2. shopmill to windows Siemens840D
    By maximusek in forum Siemens Sinumerik CNC controls
    Last Post: 02-27-2012, 05:41 PM
  3. Looking for bead insertion machines
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-23-2010, 06:08 PM
  4. Helical Help
    By 24kilo in forum G-Code Programing
    Last Post: 03-26-2009, 10:44 PM
  5. G2/g3 Helical In Yz(g19)
    By leggetmachine in forum G-Code Programing
    Last Post: 03-22-2006, 11:48 PM
