Results 1 to 2 of 2
Thread: Optoform 50 Doing my head in.
    Registered ImanCarrot's Avatar
    Nov 2005
    UK
    Would someone be kind enough to tell me of any software that would mae my Optofrm 50 lathe behave like a conventional CNC machine (with G and M codes etc) instead of the useless heap of **** that it does at the moment trying to second guess every move you make?
    I'm making optical aspheric components in plastic, aluminium and germanium etc. The machine is controled using Multi Curve Generation Software (although that's not what I call it- I got a few more choice names for it).
    The problem is it thinks it's making contact lenses so assumes that one face if convex and the other concave amongst other assumptions.
    Many thanks in advance.
    Iain
    Nov 2006
    brazil
    Hello Iman
    Good talk with somebody that use Optoform Machine, I work with intraocular lenses. we have two Optoform40 and on next month we will receive an used Optoform50, we make both side of the biconvex lens using convex and concave option without problem, let me what do you need?
    Regards
    fernando
