Hi!
One of my friend has a bridge saw (stone industrial machine). To controll the cutting position and the thickness of the balde the machine has an Omron CP1E-N40DT1-D PLC.
A few weeks ago, he started to use a kind of blade, which thicknes is not included in the possible programmed options, so I want to modify the software.
I downloaded it form the PLC, this is a cxp file. I started to search for editor to edit it, but I can only find CX-Programmer, and that is an axpensice application (for business use it is ok, but for one time...).
I would like to ask you, maybe somebody knows a similar program.
