MAKE : KIA
MODEL : KIA 15
SL.NO. : 15428
WE HAD PROBLEM OF CMOS VACANT AREA ERROR ON YANAC LX3 CNC CONTROLLER . FOR WHICH WE HAD TO ERASE ALL THE PARAMETER.
AFTER ERASING THE PARAMETER WE HAVE ENTERED ALL THE PARAMETER AS PER THE SHEET COME ALONG WITH THE MACHINE. HOWVER
STILL FOUR PROBLEMS ARE PENDING , WHICH ARE AS FOLLOWS.
1. MPG DOES NOT WORK AT ALL FOR X AND Z SELECTION . ( WE HAVE CHECKED THE MANUAL PULSE GENERATOR AND IT FOUND TO BE OK. ALL THE PARAMETER AS PER YASNAC LX3 MANUAL FOUND TO BE OK. )
2. SPINDLE S CODE 4 DIGIT COMMAND DOES NOT WORK , HENCE SPINDLE DOES NOT ROTATE ( IF WE GIVE EXTERNAL REFERENCE TO FUJI MAKE SPINDLE DRIVE THEN SPINDLE ROTATE ). IT IS OBSERVED IN LX3 DIAGNOSTIC THAT CONTROLLER IS NOW WORKING WITH S2 DIGIT COMMAND .WE HAVE CHEKDED THE PARAMETERS AS PER MANUAL AND FOUND TO BE OK .
3. SPINDLE SPEED DISPLAY DOES NOT COME , HENCE IT DOES NOT WORK IN G99( MM/REV AND THREADING) MODE. WE FOUND HARDWARE WISE SPINDLE ENCODER IS HEALTHY AND IN DIAGNOSTIC IT DISPLAY THE COUNTS .
4. ALSO IN OFFSET PAGE TOOL ORIENTATION CODE IS NOT DISPLAYED .
PLEASE HELP US IN SOLVING THE PROBLEMS OF THE MACHINE.
