Results 1 to 2 of 2
Thread: Hitachi Seiki Micon 16-II
    Jul 2007
    I'm hoping to find some M16-II expertise who can help.
    Have a Hitachi Seiki HC400 with a Fanuc 15MA married to a Micon 16-II. Machine was running fine today for a few hours with no problems and then stopped in the middle of a tool change. The Fanuc screen showed overtravels, hard and soft, in all 4 axis'. The M16-II screen was blank except for an inverse SLBUS NOT READY #nn, then flipping through all the SLBUS interface numbers (#01, #03, #04, #06, $0F). I can not get any other display to show on the M16-II screen.
    The red TX led on the bottom of the M16 main board is on solid red. All other leds that I could find on the slave boards that usually indicate activity on the SLBUS are off. I have a 5V LED (LED6) lit on the M16 board, but all others I could find are off. I can see 3 red leds lit on the power supply, 1 green led lit, and one green led off. I have no documentation for this power supply, so I do not know what is supposed to be on and what is supposed to be off as far as the LEDs are concerned. I checked power in and the on board fuse on the power supply, all check good. I am getting good readings on the +5V, the 24V, the +15V, and -15V coming off the power supply, but the +7.5V and -5V readings are bad. Does the M16 use these voltages to power communications to the SLBUS??
    Any help would be greatly appreciated. I don't mind hunting down or having repairs made to the boards, if I would be more sure of the problem.
    Ken
    Mar 2012
    Hi
    I'm just starting learning Hitachi Seiki on VM40 with seico and micon II.
    Still waiting?
    Power Supply: 7.5V goes on SLbus and supplies all I/O panels.
    Check for ground on it (disconnect cable on ditribution PCB)
    Let me Know
    Gilles
  1. Need Help!- Micon 16 hitachi Seiki Secos II - ladder save
    By Dancy in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 07-24-2011, 11:39 AM
  2. Need Help!- Hitachi Seiki Pallet loader PL 400 Micon 16 electrial manuals
    By orchidlane in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 07-22-2011, 11:14 AM
  3. Problem- Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori lathes
    Last Post: 05-04-2011, 11:12 PM
  4. Problem- hitachi seiki with Fanuc 6MB and Micon 16
    By F.Sharifi in forum Fanuc
    Last Post: 06-30-2010, 07:13 AM
  5. Need Help!- Hitachi Seiki
    By 03clipse in forum General Metalwork Discussion
    Last Post: 04-07-2010, 10:14 AM
