Results 1 to 8 of 8
Thread: What Drives and Power Supply do I need?
    Mar 2005
    Question What Drives and Power Supply do I need?
    I have narrowed it down to the Granite drives or the Dugong drives for my conversion and I am wondering about the power supply.
    Can I use the original power supply that is with the mill ,or do I have to have a power supply for each individual drive.
    The mill is an Excello 406 cnc mill it has 85volt 28amp 1700rpm servos and it has the old Bendix Dynapath 5M control and tape reader and old Westamp drives that still work. I am also thinking of going with Mach3 too.
    If anyone has any other opions on the drives or power supply or anything else please let me know what you think.
    Thanks Mike
    Dec 2003
    The original power supply should be fine, you can disconnect the tach's if the motors have, I usually just remove the brushes.
    Mar 2005
    Thumbs down
    I have just found out that if you run 2 servos off of the Granite drive its only good for 20amps per drive and my motors are 28amps so unless someone can tell me different I guess I will have to go with the Dugong drives. This stinks because I was really leaning towards the Granite drive.
    Thanks Mike
    Dec 2003
    Quote Originally Posted by CATCH22 View Post
    Thanks Mike
    Are you sure that is maybe Peak current and not continuous?
    Mar 2005
    Question
    Hi AL,
    At 20 amps per motor on the drive and my servo motor says 28amps on the tag do you think that these Granite drives would still work for me if the 28amps are peak amps.
    Thanks Mike
    Dec 2003
    If they are replacing the Westamp drives I am thinking of that were fitted to many of these type of mills, I would think they should.
    The 10F which was the highest rated was good for 15A continuous.
    Mar 2005
    Question
    I just started taking apart the old controller and I got looking at one of the other servo motors and it says .7 amps 85volts can this be right only .7 amps the tag I was trying to read before was upside down and I misread it I think.
    Thanks Mike
    Dec 2003
    If they are off a 604, they would be a bit bigger than that?
    My Excello SEM's are 17A at rated stall torque.
    1. controller power supply 115/230v OK for Australian power?
      By Momill in forum Australia, New Zealand Club house
      Last Post: 07-07-2011, 12:06 PM
    2. G250 Drives with 56V Power Supply?
      By Adamj12b in forum Gecko Drives
      Last Post: 02-19-2010, 09:00 AM
    3. OT: (Larger) machine Rutex drives, 42in/LB DC brushed servos, power supply for sale
      By PoppaBear10 in forum Bridgeport and Hardinge Mills
      Last Post: 11-08-2006, 08:50 AM
    4. Power Supply from a computer power supply
      By jmytyk in forum General Electronics Discussion
      Last Post: 01-11-2006, 03:56 PM
