Results 1 to 6 of 6
Thread: controller questions
    Nov 2006
    I can finally operate my MHP mill using the controller and drip feeding programs to it.
    So now for the 1001 questions I will have.
    The biggest question is how do the fixture offsets work. With my oxy flame cutter and mach, I just jog the cutter to where I want it to start, zero the axis and that point is now 0,0,0
    On the mill, I cant figure this out. I know where the fixture offset page is, and I can input information to where I want to start, and it does not change anything.
    Can someone point me in the right direction?
    Steve
    Dec 2003
    G54 to G59 are your work coordinate references, G53 reverts back to machine 0.
    Nov 2006
    Al-the-man
    I don't have those g code numbers.
    Here is a list I have
    G0. Positioning rapid
    G1 linear contour
    G2 clockwise contour
    G3 counter clockwise contour
    G4 dwell
    G9 decel
    G17 xy plane
    G18 xz Plane
    G19 yz plane
    G27 set absolute offset
    G40 tool compensation off
    G41 simple tool comp left
    G42 simple tool comp right
    G45 block insert left
    G46 block insert right
    G70 inch
    G71 metric
    G79 chip breaker
    G80 cancel fixed cycle
    G81 drill fixed cycle
    G82 spotface fixed cycle
    G83 peck fixed cycle
    G84 tap fixed cycle
    G85 bore fixed cycle
    G86 bore with orient
    G89 bore with dwell
    G90 absolute mode
    G91 incremental mode
    G92 position register preset
    G99 tool change location
    I an not going to pretend that I know what even half of that means
    Steve
    Dec 2003
    Strange you have a fixture offset page but no means of accessing them?
    What does the manuals say?
    Nov 2006
    Al-the-man
    If I only had a good manual
    I do have two screens on the controller that deals with off sets. The first is called fixture offset and the second is tool offset
    Steve
    Dec 2003
    Either of these any good?
    Cutter Compensation
    http://www.instruction.greenriver.ed...r/NC%20PGM.pdf
    PM the poster in the first link, maybe he can help.
    1. Motor and controller questions
      By sYmbot2 in forum CNCzone Club House
      Last Post: 10-11-2008, 01:43 AM
    2. Questions on the original UHU controller
      By southernexplore in forum UHU Servo Controllers
      Last Post: 08-16-2008, 01:52 PM
    3. Newbie- UHU servo controller questions
      By cnc2 in forum Servo Motors and Drives
      Last Post: 04-02-2008, 06:19 PM
    4. Stepper controller questions
      By petec in forum General Electronics Discussion
      Last Post: 04-26-2004, 08:15 PM
    5. Some basic controller questions
      By Mwilhelm10 in forum General Electronics Discussion
      Last Post: 10-09-2003, 01:45 PM
