this is should do it..
but jery at anilam has this info if you need it..
there are several different models.. this should be yours.. though..
good luck..
Greetings to All
I have a Bridgeport fitted with Anilam 3000M control and I am using a "Handy Pulser" remote handwheel unit (supplied by Anilam). Unfortunately the cable has pulled out of the 25 pin "D" plug which plugs into Anilam cabinet. I need a connection diagram to enable me to re-solder these connections. Can anyone help? Also can anyone give me email adress of Anilam technical support in USA
Nortonxsu
good luck..
