Results 1 to 5 of 5
Thread: Calculating acceleration rates
    Gold Member
    May 2005
    Does anyone know how to calculate this formula ?
    Acceleration for my controller is specified as "inches per minute per second"
    a. If my acceleration rate is 500 inches per minute per second
    b. My target speed is 100 inches per minute.
    What distance (thousands of a inch or inches) would be required to reach the target speed from a dead stop ?
    Thanks, Dean
    May 2003
    Assuming straight line acceleration - 1/5th of a second.
    Gold Member
    Dec 2004
    Newtown, CT, USA
    fyffe555 is correct that it will take 1/5 of a second.
    Your question is what distance it will travel.
    s = a t^2/2 (the distance equals 1/2 the acceleration times the square of the time).
    Convert the acceleration from inches per minute per second to inches per second per second => 50/6 = 8.33 inches per second per second.
    Then the distance = 8.33 * .2 * .2 / 2 = .167 inches
    See, I knew that high school physics would come in handy some day. Thanks to "Doc" Rosenberg, my physics teacher -- Dead, but not forgotten.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Gold Member
    May 2005
    Smile Thanks
    Thank you both very much for the response, I guess I should of took physics in high school instead of auto shop (can't work on todays cars anyway)
    Thanks, Dean
    May 2008
    Hi All.
    How do you calculate the time and distance if the path is not a straight line?
    1. Calculating gear ratios?
      By CNCadmin in forum Mechanical Calculations/Engineering Design
      Last Post: 06-21-2008, 07:22 PM
    2. Calculating current limiting resistors (I need serious help)
      By Konstantin in forum General Electronics Discussion
      Last Post: 07-25-2005, 05:10 PM
    3. Postage Rates
      By fragger6662000 in forum Hobbycnc (Products)
      Last Post: 04-13-2005, 04:03 PM
    4. Mach2 for high feed rates?
      By InsaneEPP in forum Mach Software (ArtSoft software)
      Last Post: 10-26-2004, 07:17 PM
    5. Acceleration
      By Photon in forum DIY CNC Router Table Machines
      Last Post: 06-03-2004, 01:46 AM
