hi todd
for putting meny tools in one holder
for an example:
analam alows for 99 offsets in its tool settings menu
Most machines have onlt around 24 holders so there fore the other 75 are not used.
When calling tool 25- 99 it will bring down t0 and ask you to insert tool.
So when setting tool
1. call tool (25 assuming you have 24 holders + 0) this will bring down holder 0
2. place tool in holder (I use a drill chuck ) i poke tool bit all the way in till it cant go up any further. (so it can be put back exactly )
3. set tool in normal fashion. before job
4. repeat 1-4 so that the tools required for the job ase set in offsets 25- 99
5. run job using the appropriate offsets according to tool used
6. on a side note. call tool then place m00 in the next line so that the program will wait for you to place appropiate tool and press go button
program would read :
t0 m6
g0 z100 *to call holder
m00
t25 m6
m00 * insert tool set as t25 in offset
g0 z100 * insert program to run for this tool
t26 m6
m00 * insert tool set as t26 in offset
g0 z100
m2
hope this can be of help
adam![]()
LinkBack URL
About LinkBacks
