Results 1 to 3 of 3
Thread: 4th axis programming
    May 2005
    Hi
    Need to know how to program a HAAS rotary table (HRT450) on a Hitachi Seiki V65 mill with a Fanuc 11M control
    It is a secondhand machine and has no documentation on the HAAS. It has it's own servo control so can I call up M functions from the Fanuc control, or does the Haas servo have to be programmed manually to work on a multi sided job.
    The machine isn't a true 4 axis
    Smoggy
    Mar 2005
    Silicon Valley, CA
    I'd go to Haas and get a handbook on it for programing and maintenance.
    I think you're saying you have the controller right? If your machine has the card installed to run the Haas, you should be able to use M/G codes to drive it. M11 (unlock), M10 (lock) etc, unless this has been changed to use something different. Otherwise, you'll need to use the Haas controller to index manually durring the program.
    You'll want the books anyway so you'll know how to set things like reference zero, indexing/rotary speeds, backlash comp, programming indexes and such.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    It may also be setup to recieve an input signal that tells it to go and then it will index the programmed amount and send a "done" signal back to the MC for it to start machining again. Often machines have spare I/O for this (M60 to M80 for example).
    Just educated guessing here.
    www.integratedmechanical.ca
  1. 4th Axis Parallel Roughing
    By whiteriver in forum Visual Mill
    Last Post: 06-17-2007, 12:10 AM
  2. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-13-2005, 10:08 PM
  3. 4th axis tutorial?
    By Monte in forum BobCad-Cam
    Last Post: 05-19-2005, 10:07 PM
  4. 4th Axis
    By UKRobotics in forum General Metal Working Machines
    Last Post: 03-19-2005, 10:25 AM
  5. Reverse thinking on a 4th axis
    Last Post: 03-03-2004, 12:38 AM
