Results 1 to 5 of 5
Thread: Software for CNC machining
    May 2009
    Luxembourg
    Cool Software for CNC machining
    Hello,
    I bought my first CNC router recently, (and my first CNC machine)
    I am trying to find software to use the machine. I have done research on the internet, however the softwares are all coming separetly (CAD, CAM ,CNC).
    I am an absolute beginner and want to start with simple softwares
    I am not aiming to do complicated projects with the machine
    Do you know any simple softwars I could use?
    Are there softwares which are "all in one"?
    Thanks for all your help
    May 2007
    vrigstad
    Nccad7
    Try to get your hands on this.It is realy simple You draw and the program makes the G kod at your command.
    When you got the program You write to me and I will tell You what to do.
    carl-eric landell Sweden
    Jan 2006
    Quote Originally Posted by skdm View Post
    Hello,
    Hi
    First you should become familar with common G code commands and the format that programs are written in.
    Draw simple shapes with dimensions like squares circles straight lines and so on. G0,G1,G2,G3 and so on Gxxx
    Learn some of the M-codes , Try and find some ISO standards G code writing material.
    Different machine manufactures use different g-code commands for different for different operations.
    Have a look at NCplot and download the free version www.ncplot.com , allows you to write g-code in text form and will simulate a 2D/3D drawing of what you are trying to write.
    ArtSoft USA - Home of Mach3 and LazyCam, www.machsupport.com has a free trial download which is widely used software and very reasonably priced join their forum lots of useful and friendly people that can assist you.
    CNC simulator www.cncsimulator.com is another example of a g-code programming writing software.
    http://www.cncezpro.com/gcodes.cfm is another example of a g-code programming writing software. Has some nice examples of raw g code format that you will find interesting.
    There are many more other software packages out there just have to search the net.
    Here is some more reading material
    http://www.linuxcnc.org/handbook/gcode/g-code.html
    http://www.4hiretek.com/gmcodes.html
    http://www.xmlcreate.com/NCGuide/NC_...ide_Index.html
    cheera
    May 2009
    Luxembourg
    I looked at Nccad7, it looks great,
    but I didn't find any links where I could get it from.
    It seems that I can only get the software if I buy a machine with it (from dealers).
    Thanks for your help
    Stephane
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    this will help you get up and running http://www.microcimm.com/psfset.html the demo will allow you to save code up to two decimal points which isn't high precision but will allow you to play
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
    1. 3 + 1 CAM software for machining a car
      By tbarnea in forum General CAM Discussion
      Last Post: 01-03-2010, 11:22 PM
    2. high speed machining software
      By hoss64 in forum Hard and High Speed Machining
      Last Post: 04-07-2009, 07:46 AM
    3. Software for simultaneous 5 axis machining
      By mudasser in forum General CAM Discussion
      Last Post: 02-21-2008, 12:23 AM
    4. Machining Software
      By Dzilli in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 06-09-2005, 01:57 PM
    5. cam software for 3 axis machining
      By mtechserv in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 05-18-2005, 04:35 PM
