Results 1 to 3 of 3
Thread: Fanuc 18M Controller won't send programs!!
    Mar 2010
    I am using a Fanuc Series 18-M controller on a Takumi V10a milling center. The manual for the controller says the Controller type is 18MC.
    I am capable of sending files to the machine fine, however when I try to receive I am getting nothing going to the PC. The Mill appears to be doing its job as it will flash "output" briefly till it completes.
    I am using BobCad Predator software to send/receive. I tried using hyperterminal to see if I could get any different results but I don't completely understand how to set this up.
    I checked to make sure that punch code setting was set to ISO.
    Is the controller using the same channel parameters (stop bits, data, parity, baud rate) to send and receive? Or could there be a different channel set up to send files to a pc with different parameters?
    Any advice will help!
    Thanks!
    Dec 2003
    A hardware checker could be used to monitor the pin status at each end of the cable, alternatively use a serial port monitor program such as http://ptf.com/download/advanced_ser...monitor/43534/
    Registered dcoupar's Avatar
    Mar 2003
    I know on the 18i series you can set prm 110 bit 0=1 to specify input and output are specified separately (in which case, prm 20-23 are used to specify the device), but I don't find any reference to this in the 18M-C parameter manual.
    I would look at the cable first. If you are using a 9-25 cable, check pin 2 to pin 2 and pin 3 to pin 3 with an ohmmmeter to make sure there's continuity. If you're using a 25-25 cable, check 2 to 3 and 3 to 2.
  1. Need Help!- Cannot Edit Programs on Fanuc 31i-A5 controller
    By PeterTheWolf in forum Fanuc
    Last Post: 07-29-2009, 04:44 PM
  2. Fanuc 0-M RS232 can recieve but not send
    By malaron in forum Fanuc
    Last Post: 10-01-2007, 11:02 AM
  3. How do I send/receive NC Programs on Mitsubishi FX EDM
    By barnescomputer in forum General Waterjet
    Last Post: 06-15-2007, 04:30 PM
  4. Send program from PC to Fanuc controller
    By derail in forum Fanuc
    Last Post: 02-26-2007, 04:15 PM
  5. fanuc 3t wont send prog.
    By AFX in forum Fanuc
    Last Post: 10-06-2006, 08:25 PM
