Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 10-08-2009, 02:05 PM
MadPickinSkills's Avatar
MadPickinSkills is on a distinguished road
arcs using I and J
Can someone give me a refresher on how the I and J codes are used or point me to a website that explains it?
Old 10-08-2009, 02:20 PM
jpgdesigns is on a distinguished road
the I & J define the center of the arc... Just keep in mind that the I & J could be relative or absolute depending on your controller... They are not controlled by G90 or G91... so find out what your controller is set to...
an example:
Absolute X & Y, Absolute I & J, Center of Arc 2,2, Radius 1, Clockwise Motion
G02 X3 Y2 I2 J2
Absolute X & Y, Relative I & J, Center of Arc 2,2, Radius 1, Clockwise Motion
G02 X3 Y2 I-1 J0
Hope this helps
Old 10-08-2009, 02:54 PM
Torsten's Avatar
Torsten is on a distinguished road
Wink
Besides been absolute or relative depending on Controller, I have seen different Controllers sometimes use opposite signs for relative addressing.
Most common when relative addressing is used it will be the distance from the tool start position to the centerpoint.
Where I = X direction, J = Y direction and K = Z direction.
Any IJK-Address amounting a Zero value may be omitted.
So for example
G17 (XY-Plane Selection)
G03 I-2.
Will drive a full circle with the center been 2 inches to the left of the current position.
Or use
G17 G03 J2.
This time the center of the 4 inch diameter circle will be 2 inch above the current position.
Hope this helps, good luck
valmet58 is on a distinguished road
Cool explanation
go see http://www.etec.wwu.edu/faculty/McKell/nccnc_prog3.pdf
Andy
Arcs Anxious Post Processors 11 09-17-2008 10:41 PM
Need Help!- I and J 3D arcs mmachining BobCad-Cam 7 02-14-2008 01:01 PM
3d arcs? stevespo BobCad-Cam 10 08-31-2007 08:02 PM
Huge Arcs Biggermens Mach Lathe 0 04-23-2007 10:49 AM
Smoothing 3d arcs? stevespo BobCad-Cam 14 04-20-2007 06:46 AM
