Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 08-03-2009, 12:59 PM
alexplace2001 is on a distinguished road
Motion Master Router with AB9/260
Hi
I'm trying to repair a Motion Master Router
(no model can be found in the machine).
The control panel shows this message:
FLASH SIMMS CONTAIN INVALID DATA
The batteries in the controller were disconected some time.
The controller is a Allen Bradley AB 9/260 RV11.01 Boot firmware Rev 2.02
the CPU card with the flash cards is: 8520-CPUX1
I'm trying to connect with the machine using the ODS software, but the version I got only supports till version 10.XX, so I recieve a message of incompatible controller.
Could anyone tell me were can I get a ODS version compatible with the 11.xx revision?
I hope this is not the case, but If the PAL and AMP had been lost where I can get them?
Thanks in advance
Alex
Tags
ab9/260, motion master, ods
New user with a Cam tech router and Master cam 7.1 and 9.1 need info Re: config jrm7997 Mastercam 7 02-04-2011 08:21 AM
Cam Tech Router Master II-No controller on Com2 tracikowal Machine Problems, Solutions , Wireless DNC, serial port 5 01-26-2011 09:31 PM
Need Help!- Siemens 810M 1720 ORD + X error (Motion Master Router) mjhjenks Controller & Computer Solutions 6 03-02-2010 04:06 PM
e36 cnc router from motion tek toronto ont woodman08 Commercial CNC Wood Routers 0 10-18-2007 04:34 PM
Motion Master router Jennifer DIY-CNC Router Table Machines 6 10-16-2004 11:26 AM
