Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 05-20-2009, 12:41 AM
dismal is on a distinguished road
problem with alpha 400 lathe spindle not turning on
Just recently acquired a Harrison Alpha 400 lathe (1995 vintage) and have a question.Had it all setup and was running perfectly for about 2 weeks now ,then I went to shut it down at the control (using the on/off buttons on the user panel) and they would not shut it down until I engaged the Estop.After restarting I now have the problem of not being able to turn the spindle on .I go through the required motions for the lathe yet it does not spin . There are not any alarms on and I checked the e stop button to make sure it was not sticking.Any suggestions would be appreciated. Thanks
Need Help!- Need Alpha cam lathe post for Fanuc. rennar80 General CAM Discussion 0 11-26-2008 03:51 PM
Need Help!- Need Alpha cam lathe post for Fanuc. rennar80 Post Processor Files 0 11-22-2008 05:00 PM
Schaublin Lathe Bosch alpha parameters Spinner560 Machine Problems, Solutions , Wireless DNC, serial port 10 08-26-2008 11:36 AM
Trying to find a part for a Harrison Alpha 400t CNC Lathe viperx204 Industrial Hobbies (Support forum) 2 04-23-2008 07:10 AM
Need Help!- Alpha Spindle alarm help rai Fanuc 3 03-04-2008 11:05 AM
