| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
Hi All, New to this. I have done a good look at what is needed to convert both my lathe and Mill to CNC control. All looks like fun. The bit I am having trouble with is that I see on some builds different gear sizes, which naturally translate to different number of ratios. So how does the system "know" that x number of turns of the stepper motor, geared down to Y = this much travel of the tool? Hope that makes sense. TIA |
| You tell the control software how many steps it takes to move 1mm.
| To slightly elaborate, you define the "gear ratio" for each axis in the control software. They can all be different, and you don't actually need to calculate/know it as you can measure actual moves to get the answer (move what you think is an inch, measure it, use that to correct the scaling factor). It is very easy to change in MACH3, and I imagine EMC makes it easy as well. |
| Step motors moves 1 step only | alecu7 | Hobbycnc (Products) | 1 | 10-16-2008 12:18 PM |
| Calculating gear ratios? | CNCadmin | Mechanical Calculations/Engineering Design | 12 | 06-21-2008 06:22 PM |
| Source for DC gear motors? | Zumba | General Electronics Discussion | 3 | 10-06-2007 10:25 AM |
| How do I calculate my gear ratios? | Apples | Linear and Rotary Motion | 2 | 09-17-2006 06:39 AM |
| Before buy the Step Motors. | samsagaz | Stepper Motors and Drives | 3 | 03-28-2005 05:50 PM |
